C253 Secure print jobs fail to authenticate
  • zyxwv88
    #16
    Ditto
    We are having the exact same issue. We have two models of Bizhub printers and about half of them the secure print works perfectly and the other half give us the "failed to authenticate" error when we try to get the job from the printer. We are using the exact same driver for the ones that can secure print as those giving the error, so it can't be that. The corrupt user box that someone mentioned could be the problem, but nothing was mentioned about how to clean it up. I was going to talk to our Konica rep who is here now about the generic mode.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      #17
      As was previously mentioned, doing a system reset procedure should correct the problem. This is a bit extreme in that it will clear out any and all user settings back to factory, along with any administrator changes and adjustments. All one-touch information will be lost, including boxes, the hard disk is formatted as part of this procedure.
      Formatting the hard disk by itself without doing the above might fix the problem, affecting just user one-touches and user boxes.
      Be sure to back up the one touches and any file contents within the user boxes that you may need (print them or download them to any PC). If doing a system clear, make note of any network settings like email or ldap or dns information.
      After doing either procedure, upload the one touches and manually recreate the user boxes.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • jma676
        Expert Tech
        • Mar 2009
        • 324
        #18
        Originally posted by Chromatik
        I understand, just post this list to expand, maybe as you say the HD is corrupt to some file that contains the same ID and pass different or the other way around, but well check out the options for printing secure in the manual.
        Service & Support | Konica Minolta Business Solutions, U.S.A., Inc.
        http://kmbs.konicaminolta.us/content...UserManual.pdf
        Tanks Friend!!!!!!!!
