C280 2008 server error on PS driver
    • 30279
    Loaded c280 64 driver on a windows 2008 server when I try to load the x86 Getting a error message on adding a x86 driver
    Pcl driver installed with no issues
  • dallas
    • Jun 2008
    • 115
    Make a remote installation from a Windows 7 x86 client with admin rights and it works.
    • ni311
      • May 2008
      • 658
      What is the error message you are getting?
      Konica Minolta Error Codes - Explanations and Solutions
        • 30279
        unable to find x86 processer
        • jma676
          Expert Tech
          • Mar 2009
          • 323
          If you installed a driver for an x86 system on a 64bit is causing a system error.
          X86 drivers are not fully compatible with a 64Bit system, although you can adapt x86 applications to run on a 64Bit system, is not proved necessary in this case.
          Determine if the system you are using is 64Bit or X86 , then you will have to correct this error completely removing the drivers installed on your system, if not have experienced in this should contact IT support.
          then install the driver version that corresponds to your system.
          (To know which system is using see system information or you can consult the Windows help system.)
          • jma676
            Expert Tech
            • Mar 2009
            • 323
            Ok, Thank you! and maybe you need post this thread here:
            Connectivity
