Konica C650 with FS-608 wont saddle stitch anythign but plain paper....
  • methogod
    • Dec 2008
    • 922
    Every where i read it claims it can staple, fold, and fold and center staple (saddle stitch) up to 80 pages, including up to 208gsm (THICK2).
    I have yet to get it to saddle stitch anything but plain paper. From both the fiery, and regular drivers, to just making copies and selecting booklet as the finishing option, it wont let me press start unless its set to plain paper, i have worked around but using 70lb in tray 1, but set it as plain (even though its THICK1.
    The product support material all say 208gsm. See here on page 13 under finishing,
    Konica Minolta provides a wide range of smart business solutions, including Printing and Robotic Solutions, Digital Workplace, Cloud Services and IT Services.
    let me know if anyone has this solution, client is getting pissy as I steered him from a C500 to a C650.
    thanks,
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Generally in commercial brochures describes the maximum capabilities of the systems as well the maximum printing speed is measurement in A4 or letter plain paper. In this case the maximum capacity of the FS-608 is obtained with plain paper.
    This description will answer the rest of your query.
    FS-608 spec =
    A. Type
    Name/FS-608 Multi folding multi stapling finisher
    Type/Staple finisher attached to the side of the main body
    B. Functions
    Modes/Non-sort, sort, offset, group offset, sort stable,folding, saddle stitching,tri-folding
    C. Stapling
    Max.flat-stapling
    -------capacity/*64 to 80 g/m2: 50 sheets or 48 sheets + 2 sheets (200g/m2)
    ----------------*81 to 90 g/m2: 16 sheets or 14 sheets + 2 sheets (200 g/m2)
    ----------------*91 g/m2 or more: 2 sheets of thick paper or more not guaranteed
    Max. saddle stitching
    -----------capacity/*
    64 to 80 g/m2: 20 sheets or 19 sheets + 1 sheet (200 g/m2)
    --------------------*81 to 90 g/m2: 16 sheets or 15 sheets + 1 sheet (200 g/m2)
    --------------------*91 g/m2 or more: 1 sheet of thick paper or more not guaranteed
    Stapling position/*Back of the corner (45 degrees, Paper width 297 mm or less),
    -----------------*Back of the corner (0 degree, Paper width over 297 mm),
    -----------------*Front of the corner (0 degree),
    -----------------*Center staple two points (Staple interval is adjustable
    -------------------------------------------between 128 mm and 160 mm.)
    D. Max. paper capacity
    Tray 1 (80 g/m2)/*Non-sort, sort,group =2,500 sheets:A4/A4S, B5/B5S, 8 1/2 x 11/
    ------------------8 1/2 x 11S, 16K/16KS,
    ------------------7 1/4 x 10 1/2 /7 1/4 x 10 1/2 S
    ------------------1,500 sheets:A3, B4S, 8 x 13S, 8 1/4 x 13S,
    ------------------8 1/2 x 13S, 8 1/2 x 13 1/4 S, 12 1/4 x
    ------------------18S, 11 x 17, 8 1/2 x 14S, 8KS
    ------------------500 sheets: A5/A5S, B6S, A6S, 5 1/2 x 8 1/2 /
    ------------------5 1/2 x 8 1/2 S
    -----------------/*Stapling =
    -----No. of sheets----------Size in the sub ----------The others
    ------per stapling-----------scan direction------------
    ----------------------------is418 mm or---------------
    ----------------------------longer-------------------------
    -----02 to 09 --------------50 copies----------------100 copies
    -----10 to 20 --------------50 copies----------------50 copies
    -----21 to 30 --------------30 copies----------------30 copies
    -----31 to 40---------------25 copies----------------25 copies
    -----41 to 50 --------------20 copies----------------20 copies
    Tray 2 (80 g/m2)/*100 sheets
    Tray 3/*Folding = A3, B4, A4S, 12 1/4 x 18S, 11 x 17S,
    ------------------8 1/2 x 14S, 8 1/2 x 11S, 8KS
    ------------------Min. : 210 mm x 280 mm (8.25 inch x 11 inch)
    ------------------Max. : 311.1 mm x 457.2 mm (12.25 inch x 18 inch)
    ------------------3 sheets folding: 25 to 33 sets
    ------/*Saddle stitching = A3, B4S, A4S, 8 1/2 x 11S, 8KS
    --------------------------Min. : 210 mm x 280 mm (8.25 inch x 11 inch)
    --------------------------Max. : 311.1 mm x 457.2 mm (12.25 inch x 18 inch)
    --------------------------5 sheets stitching: 15 to 20 sets
    ------/*Tri-folding = A4S, 8 1/2 x 11S, 16KS
    --------------------1 sheet folding: 50 sets or less
    E. Type of paper
    Size/*A3, B4S, A4/A4S, B5/B5S, A5/A5S, B6S, A6S, postcardS, 5 1/2 x 8 1/2 S,
    ------8 x 13S, 8 1/4 x 13S, 8 1/2 x 13S, 8 1/8 x 13 1/4 S, 12 1/4 x 18S, 11 x 17,
    ------8 1/2 x 14S, 8 1/2 x 11/8 1/2 x 11S, 7 1/4 x 10 1/2 /7 1/4 x 10 1/2 S, 8KS, 16K/16KS
    ------Min. : 100 mm x 139 mm (4 inch x 5.5 inch)
    Type/*Plain paper, thick paper 1/1+/2/3/4, OHP transparencies, postcard, envelope, label, -------letterhead, long size paper (#1)
    (#1): Long size paper needs to be 1200 mm (47.25 inches) or less in length.
    Weight/*
    64 to 300 g/m2
    sorry need weight measurements in lb, I have no time to convert them. in metric mode gram/m2
    Pound (mass) - Wikipedia, the free encyclopedia
    I'm joking:
    • methogod
      • Dec 2008
      • 922
      That would be perfect, if it works, client wants to print 28 page booklets on 11x17 or 12x18, thats 7 sheets, 6 of 70lb (technically thick1, but can run through as plain paper), and a cover of THICK1+ (way less then 200gsm.
      I am more concerned that it wont even let me, run it on anythign but plain paper. Tried even puting the 70lb in tray 1 as plain paper, put the cover stock, 65lb cover (120gsm) in tray 2, and just tried to make it pull the cover first, then the rest plain paper. Every spread is 4 pages, so in theory, 15 pages plus cover is a 64 page booklet.
      I am only trying to do 7 pages (11x17) then saddle stitch them.. should be able to do it. Doing to work around is fine, but there are some print quality issues when you tell it that THICK1+ paper is plain paper, the machine doesnt adjsut the fuser or the speed for the thickness...
      I know there is a firmware both for the MPF and for the fiery, but I am cool even if i can just use it without the fiery.
      if anyone wants to work with me, i will pay them, for their time and for the firmware. I know how to install it, just my Konica guy makes it sound like its rocket science, and firmware although with older machines can mess stuff up they can only help in this case.
      • jma676
        Expert Tech
        • Mar 2009
        • 323
        In Pdf =
        FINISHING TRAY 3: Plain Paper (17 lb. bond to 24 lb. bond)
        FINISHING TRAY 3:Center Staple & Fold (5 bound sheets): 15 to 20 sets or less
        -----------------------------Half-Fold (3 sheets): 25 to 33 sets or less
        ------------------------------Tri-Fold (1 sheet): 50 sets or less
        Center Staple
        Plain Paper and Fold/ (17 lb. bond to 21.25 lb. bond): 20 sheets : (equivalent to 80-page booklets);
        -------------------- (21.25 lb. bond to 24 lb. bond):16 sheets : (equivalent to 64-page booklets)
        Saddle stitching /A3, B4S, A4S, 8 1/2 x 11S, 8KS
        Never try to pass heavy paper by another type, is not recommended and may cause severe problems.
        I think the possibilities are limited so as described in the specifications, you are trying to overcome that capacity, in my opinion contact a representative KM can explain personally, the maximum capabilities of the FS-608.
        • ineo+6501
          • Mar 2010
          • 262
          I have several customers who do this job regularly with great success.
          This is how I have got them do it:
          Print the front cover 1st using the correct settings for the thickness. Then run the rest of the job using cover insertion mode (BLANK), feeding the cover from either the bypass tray or ideally from the PI attached to the finisher. If you don't have a PI, I would recommend getting 1 if your customer wants to do this alot.
          • methogod
            • Dec 2008
            • 922
            iLL TRY IT TODAY, PULLING COVER AS THICK1 FROM TRAY 1 AS A PREPRINTED BLANK PAGE. THEN RUN THE 28LB AS PLAIN PAPER. ITS ONLY 7 SHEETS INCLUDING THE COVER SHOULD BE OK.
            JUST CANT GET IT TO PRINT AND PULL THAT COVER, ONLY WANTS TO CENTER STAPLE AND FOLD PLAIN PAPER. CAN YOU LOOK FOR FIRMWARE THAT ADDRESES THIS...
            • ineo+6501
              • Mar 2010
              • 262
              Sorry, just to be clear:
              If the customer wants to produce say 50 booklets, print 50 x the front cover using eg thick 1, then put the cover back into the machine in the bypass tray but change it from thick 1 to plain paper.
              This has little or no effect on the quality of the cover as it has already fused. The machine will allow you to fold and staple the cover as an inserted sheet as long as the tray setting is plain paper.
              • methogod
                • Dec 2008
                • 922
                The machine will only saddle stick "plain paper", no matter what i do, prepinting the covers - and telling it to pull from the bypass as a blank that i have not tried yet. But it should let me do 7 pages of plain paper + cover that thick1 or thick2.
                I am being told firmware can be the issue, on the mpf, as even when i copy and select booklet at the finising option it wont work unless its plain paper, i can try to make it pull a thick one cover and see if that does it.
                Trust me i am getting a c6500 when we move in january...
                • Stirton.M
                  All things Konica Minolta
                  • Oct 2009
                  • 1804
                  Firmware is not the issue. There are no "fixes" to this on the firmware level.
                  The finisher is meant to be a light duty finisher for office environment. Exceeding its physical limits is not supported by KM. There are tricks, as previously stated, but do not expect the machine to put up with those tricks for long.
                  "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                  ---Groucho Marx
                  Please do not PM me for questions related to Konica Minolta hardware.
                  I will not answer requests or questions there.
                  Please ask in the KM forum for the benefit of others to see the question and give their input.
