Code C9401 on a C352 - Any relevant fuse(s)?
  • mrwho
    Major Asshole!
    • 4299
    [Electrical] Code C9401 on a C352 - Any relevant fuse(s)?
    Hello there, guys and girls. I've got a customer owning a C352 with a C9401 (exposure lamp doesn't turn on). Before ordering a new exposure lamp, are there any relevant fuses that I could go there and check for continuity?
    Cheers!
    Mascan42
    Ibid
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Bizhub C352 C9401: Exposure lampโ€™s failure to turn ON
    No fuse, maybe some component in the scanner assy is very strange that the lamp causes the blowing of a fuse, it would be the case, if someone was manipulating some of these components.
    well you know this step.
    Relevant electrical parts / Scanner assy - Flat cable/ Image processing board (IPB)
    Description = โ€ข The average output value of the CCD sensor with
    the scanner at its standby position is a predetermined
    value or more at the end of a scan job.
    Action =
    1-check the exposure lamp, lights correctly during scanning, mirrors and CCD also must be properly installed.
    2-Check the flat cable for proper connection
    and correct or change as necessary.
    3-Change scanner assy.
    4-Change IPB.
    I now ask, what is the code, if the exposure lamp is blown?
    • mrwho
      Major Asshole!
      • 4299
      Thanks for your input, but the customer confirmed by phone that the exposure lamp isn't turning on, so I'm ruling out the CCDs for now.
      We have a C450 inhouse, which shares the lamp and inverter board - we're going to take them and see what's up.
      I'll be leaving feedback!
      Mascan42
      Ibid
      • mrwho
        Major Asshole!
        • 4299
        Forgot to tell you what happened, so here it goes (better late than never, I always say - unless we're talking about death or taxes... But I digress...)
        As I arrived at the customer's, I noticed one of the exposure mirrors had fallen off. Simple fix, problem solved!
        Cheers!
        Mascan42
        Ibid
        • jma676
          Expert Tech
          • Mar 2009
          • 323
          Cheers!
          !!!!!This is called an expedited service!!!!!
          • jma676
            Expert Tech
            • Mar 2009
            • 323
            Cheers!
