Konica 7075 sc 42-04 and 46-25
  • potro_salvaje
    • Sep 2010
    • 23
    help me with this problem guys, im buy recently this machine
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Konica 7075 - SC : F42-04 - F46-25
    mmmm, I think you disassembled without knowledge, or to an error when connecting harness again.
    Well...! contact Technical Service that may guide.. or follow the recommendations.
    F42-04 - Check on FM5 (write section cooling 1) rotation and 24 V power supply.
    The FM5 EM signal was abnormal at specified time after turning ON of FM5/8 (write section cooling 1/2). At specified time after turning FM5/8 OFF and ON again, the FM5 EM signal is still abnormal and an abnormal detection signal (24 V off) is detected.
    DCDB (DC drive board)(7075 only)
    FM8 (write section cooling 2)
    ICB (image control board)
    DCPS2 (DC power supply unit 2)
    ACDB (AC drive board) (7085 only)
    Harness short circuit with the ground Connector connection failure.
    E46-25 - AOC/AGC error
    - The light blocking cover and lens cover are removed from the read section.
    - The A/D conversion board connector is disconnected.
    - The power cable of A/D conversion board is disconnected.
    - The IC protector on the A/D conversion board is blown out.
    - The exposure lamp intensity is excessive.
    - The exposure lamp does not light.
    ADB (A/D conversion board)
    L1 (exposure lamp)
    and a guide to clear jams as a gift!
    • potro_salvaje
      • Sep 2010
      • 23
      first thank you very much for your great help,
      if not familiar with this machine and take it apart, but the reassembly forget to connect the party with three peaks is close to the drum and then I made a copy, and there fans the back started very quickly and I It Works came these two errors.
      I really need help because I have no idea how to fix and service the company which purchased the machine tells me this holiday and will return within 1 month.
      would be very grateful if you gave me the service manual, thank you very much anyway.
      ah I forgot, sorry for my bad English im from south america
