Yes big papa is correct. You can't disable this function but you might be able to make it copy longer between stabalizing. First make sure yo run gradation adjust on after you replace any IU and in tech rep mode under image adjust and then stabalizer switch to span 2. This should make it go a bit longer between stabalizing. Hope it this helps.
