How to reset a network card in a C452
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    #16
    Originally posted by jrf
    Just to let you know that clear all under initialize in service mode is the only way to clear all network settings. There is no novram recover tool as most settings have been removed from the novram. Thanks for all posts
    It seems that we have never understood, or the case .. never understood you want to know!.
    I think that seeks to This:
    as I said before:Check: User's Guide (Network Administrator)
    You, Maybe, not compose well the question, or want to refer to something else, ooooh... read the manual, if you want to restore any settings, just do it, you want to configure the IP address again, between a new and longer.
    Anyway.
    Initializing the configuration information
    You can initialize the network settings (to the factory defaults), reset the controller, and delete the entire destination information.
    1-Network Setting Clear:
    In the administrator mode of PageScope Web Connection, select "Maintenance" - "Reset" - "Network Setting Clear".
    (If Enhanced Security Mode is enabled, this menu item will not be displayed.)
    *If you click [Clear], the network settings of this machine are cleared to the factory defaults.
    2-Reset:
    In the administrator mode of PageScope Web Connection, select "Maintenance" - "Reset" - "Reset".
    *If you click [Reset], the controller is reset.
    • jrf
      • 142
      #17
      Your information is correct JMA676 but if other details such as as bios name and in our case where discovery protocol was switched off by some click happy IT guy your solution will not work.
