DI2510....USB
  • connecticcut
    • Feb 2010
    • 53
    DI2510....USB
    My computer don't see (connexion) the copier.I have to install driver but it don't print.
    Maybe,i forget to modify parameters on the machine DI2510.
    What's solution?
    thanks
  • Emjay
    • Jul 2009
    • 42
    Not sure I fully understand your question. This model does not have USB . Can you be a bit more specific about how the copier is connected and what you are trying to achieve?
    • connecticcut
      • Feb 2010
      • 53
      you have 2 connectors = RJ45 (network) and USB.
      the customer hasn't network and i use the second connector but i don't arrive to print.
      • connecticcut
        • Feb 2010
        • 53
        it's ok now.Problem with network card (to exchange)
        • aleksander
          • 378
          you are using optional NC4 & Pi3505e. Your problem is in your NC4.
          • connecticcut
            • Feb 2010
            • 53
            thanks
            i don't find driver for vista (i have pcl and not ps card).It's necessary to replace pcl for PS card?
            • connecticcut
              • Feb 2010
              • 53
              i have to install PS card.It's ok for XP but it don't print with vista.
              • RRodgers
                • Jun 2009
                • 1944
                just set it up to use an HP LazerJet 4 driver and it will print. You won't get much else out of it, but it will print.
