FS-618 finisher for Konica Minolta C550--- rear stapler doesn't staple
  • tbsoa
    • Aug 2009
    • 15
    [Electrical] FS-618 finisher for Konica Minolta C550--- rear stapler doesn't staple
    Hi. On this FS-618 finisher when I select 2 point stapling, no problem. When I select single point stapling, rear stapler, I see two holes but no staple. I already switched clincher units and used jig for alignment. I checked all harnesses. Please help. Thank you. You can reply to Gregoryt4@gmail.com
  • mo0651
    • 1054
    If you can see holes, it is hammering. check the staples themselves. sometimes a broken stack can cause a misfeed of staples into the clincher.
