wasnt initializing, now is but error codes
  • codeboy
    • Jul 2025
    [Error Code] wasnt initializing, now is but error codes
    bizhub 200, used to not get past "initializing", now it does for some reason, and beats itself up and gives an error code...
    i can slide the scanner bar to the right, but then it cruises back to the left... then beats itself up
    !*! ABORT !*!
    code = 0x00dc0652
    tskname = tRT22601
    tskID = 0x00005849
    sp = 0x89f308a8
    ra = 0x812733a8
    build_3034.070219
    Any Ideas?
    Thank you
  • HuronMan
    • Jul 2009
    • 68
    Per KMBS solutions.
    0X00DC0652
    Power Supply failure.
    Check the Power Supply Unit (PU1) at connector PJ5PU1. The voltages should read as follows:
    PIN # DC VOLTAGE
    1 3.3
    3 5
    7 24
    9 12
    Note : If these voltages do notmatch the above readings,replace the Power Supply unit (p/n 4040 6201 01).
    Open 24V DCfuse (F222) on the BCRS due to M12 (Scanner) harness pinched by the right cover.
    bizhub 200/250/350
    Change routing of the M12 harness (p/n 4040 1505 01) for theScanner motor (p/n 4551 2013 01) thenreplace the BCRS (p/n 4551 2033 01 for bizhub 350
    and p/n 4551 2034 01 for bizhub 200/250 ).
    • codeboy
      you have a pic by chance?
      you have a pic where the location of PJ5PUI is located? is the ground pin obvious? (ie black?)
      where is DC fuse F222, or where is the BCRS and i can locate fuse by the markings on the board...
      Im an IT guy not a copier guy, so any help is great thank you.
      David
