Hey everyone. Anyone have any ideas why the control panel for a Konica Minolta C252 would keep uncalibrating itself? It will be fine for a week or so then you'll try to select something and it selects an item much lower than where you pressed. It works once you go through service mode and recalibrate it. Is replacing the panel the only permanent resolution?
Thanks in advance.
Thanks in advance.
