konica minolta DI-450 memory error
  • technician
    • Aug 2010
    • 25
    [Error Code] konica minolta DI-450 memory error
    Hello every body
    I am facing a problem in konica Minolta DI-450 in customer side.
    machine show the error code F12C. (memory error)
    I replace the logic board but the machine show same problem.
    please give me suggestion about the error
    Thanks for your reply
  • jotunn
    • 618
    First of all give us a real error code - in form C-xxxx.
    In case of memory errors you can try to check if your machine has an optional PWB-M board (under scanner) - it may be faulty.
