c252 no display
  • NIKIL.KP
    • Jul 2010
    • 30
    c252 no display
    Hi all
    when the c252 machine is on,the display will give sand time and goes off completely.i rewrite the firmware of mfp,printer and scanner.download was completed and in mfp it showed download completed with checksum.Please advis eon this issue.
    thankyou
  • bizhub1
    • Sep 2008
    • 230
    I would check with KM, I believe their is a warranty issue for the control panels on this model.
    • NIKIL.KP
      • Jul 2010
      • 30
      Sorry t o say that i have interchanged the control panel but still problem exists
      • bizhub1
        • Sep 2008
        • 230
        Adobe - Adobe Reader download - All versions.
        IMPORTANT: All requests for NVRAMs must be approved by the SSD Hotline and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
        Before replacing the NVRAM, thoroughly troubleshoot the problem. The NVRAM should be replaced only as the last resort. Many times replacing it DOES NOT solve the issue and, when it does, only a setting in the NVRAM may have caused the problem.
        • mo0651
          • 1054
          NVRAM. Keep your firmware handy.
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            Always worth while to look at the cables between the control panel itself and the MFP....there is a board under the scanner unit (behind the CCD), PWB-C which can also be at fault for some problems with the panel. Check the ribbon cable and the heavy interface cable at both ends...sometimes oxidation is enough to cause issue. See attached image, red circled items....or for that matter, the C-board itself may have failed.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
