imagistics cm 2520 error code c 2557
  • lightningjeremy
    • Jul 2009
    • 139
    customer brought this machine to our shop for repair. they had it laying on its back in a minivan! after we fired it up, c 2557 code came up. they said this was the code they brought it in for. we explained to them how big of a mistake it was to put it on its back. can someone tell me the code description? also what is the minolta equivelant model? thanx
  • marco1508
    • Sep 2010
    • 32
    you need reset the drum, may be the drum module move of you site position, the equivalent or the copier wich is equivalent is y the bh 222, I have the service manual, ensamblerman@gmail.com
    • brent
      • Nov 2008
      • 1214
      if it is the same code as i think. the drum counter was reset without replacing the drum and the developer at the same time and doing a proper f8.
      the older di 3510 series machines you could reset the d rum counter and get another full life out of it. I don't have a compatability chart on this one. but if it is equivilant the the bizhub 200 family. replace the drum unit and developer and then reset the counter.
      brent
      • lightningjeremy
        • Jul 2009
        • 139
        are the drum unit and developer seperate on the this machine? supplies and parts seem to be hard to find for this machine
