I looked in the manual I have and it is not listed, how ever here are the three ways to clear the code
1. you can do the trouble reset using the switch on the right side of machine to the left of the network port
2. open and close the front door
3. turn machine on and off using main switch on lower left of machine.
I suspect it is a firmware code, I would try flashing machine to at least level 80 to start.
