Di351f fax problem
  • NickTTTA
    • May 2025
    Di351f fax problem
    We got hit by lightning, and the fax line going into the copier/fax was not protected. We no longer get a dial tone, so I assume the card is bad. The printer/copier still works great.
    I can not find the replacement
    here are the pics, and #s
    This card is under the plastic where the paper comes out after being printed. The phone jacks you see are connected to the jacks on the outside of the printer via a phone line.
    There is just a 15 pin connector (2nd pic on the bottom of the board, peach/orange in color) that connects the scanner to the modem, then the phone lines going out to the world...
    PLEASE can someone tell me where to get this
    -Thanks!
  • bgbas
    • Feb 2007
    • 60
    Are you sure the fax line didn't get fried? An easy test would be to plug a analog phone into the wall jack and see if you get a dial tone.
    • NickTTTA
      Already tested it. We have an older fax machine plugged in right now.
      Any idea where to get this card? Or who makes it?
      • bgbas
        • Feb 2007
        • 60
        The minolta part # is 4015103901. Try calling 800-456-5664 this is the KM service supply number but they may be able to direct you to parts dept
        • NickTTTA
          You, my good sir, deserve a beer!
          Cheers! I will let everyone know if they were able to help me on Monday.
          hope you all have a great weekend!
          Thanks!
          • wagon
            Village Idiot
            • Dec 2006
            • 654
            Hang on, hang on!! BEFORE you rush out and buy a new fax card, please check the 2 green fuses - F1 and F2 - shown on the first photo about half way from the top ... AND any other 'picofuses' that look like that on that pcb. Any competant TV repairman (or electronics technician, etc.) can aquire / replace those if they have failed - and it will be $$ cheaper.
            Kendall.
            If you are hitting your head up against a wall it always feels better when you stop.
            • NickTTTA
              Kendall.
              THANKS!!!!!!!!!!!!!!!! 19 dollars, and it's working PERFECT!
              THANK YOU!
              • wagon
                Village Idiot
                • Dec 2006
                • 654
                I am not as dumb as I look!
