jam code 7216 a lot of times in a day...
any idea???
thanks in advance
What job is being run ie stapled/folded or straight copies? Also where exactly are you removing paper from. The code refers to the finisher so you need to see where the paper is stopping and then work back from there. Also early firmware can cause this, needs to be version 30 or higher..
