Minolta CS Pro EP5000 Service Mode
  • Copier_Guy
    • 543
    Could someone please instruct me on how to enter service mode for the Minolta EP5000 and how to clear a Maintenance message. I don't know the exact message since I haven't visited the site yet. Just the info the customer has given me. If someone has a detailed service manual for this unit, that would be great and even better. Thanks all for your time and consideration.
  • leo34staffs
    copierman
    • Aug 2007
    • 502
    im sure its stop 0 stop 1 then that will take you into svc mode then got counters, theres about 10 touch boxes on there so you will find it by trial and error.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • Copier_Guy
      • 543
      Thanks alot. Once I get in there, I'll be able to figure it out.
      While I have you here, would you know what the Error Code C0996 relates to?
      Thanks again.
      • bgbas
        • Feb 2007
        • 60
        I believe that code relates to the the 3rd or large capacity cass. Those lift gears go out periodically.
        A nice feature of these machines is that the counter, trouble tab in the service mode will tell you what the error code relates to.
        Good luck
        • Copier_Guy
          • 543
          Good luck
          Thanks, it did just that. I have a manual I bought from some site, but I think it's incomplete, because it just has theory of operation and not troubleshooting or error codes, so if anyone has this manual, could you please share with me. Thanks again.
          Thanks for your help bgbas.
          • Darren King
            copiertech
            • 652
            EP5000
            I don't have a manual to send you, but I can tell you that code has to do with the large capacity tray's failure to open after the button on the front has been pressed. There is a solenoid in the back that releases to open the drawer. If the drawer is opening and still getting the code the sensor near the solenoid is likely dirty.
            Hope this helps
            Darren
            • Copier_Guy
              • 543
              Hope this helps
              Darren
              Thanks Darren,
              That helps a lot. The tray does open and I see the solenoid and latch mechanism in the rear. I'll check that sensor the next time I'm there.
              Thanks for the help.
              • chand
                • Oct 2007
                • 12
                Hello.
                I want a service manual of ep-5000..
                Please send me this to my mail
                owninn@msn.com
                i am waiting your reply
                from
                U copier
                Rahim Yar Khan
                Pakistan
                • denis stokes
                  Originally posted by chand
                  Hello.
                  owninn@msn.com
                  from
                  U copier
                  Rahim Yar Khan
                  Pakistan
                  Hi i have an EP 5000
                  The copier generally works well but it produces
                  a smudge on the right hand side of each copy.
                  I have changed the E ram module on the back with another and this makes it worse. can you please help me. iam also looking for the general service codes
                  • deep
                    • Jun 2008
                    • 208
                    Hi denis,
                    What make you change the RAM for a smudge copy?
                    Change the RAM Board back.
                    It should be toner leaking from the DV or upper fuser roller failed.
                    Check it.
                    Kenny
                    • denis stokes
                      Thanks for the info.
                      I ahve replaced the ROM.
                      Can you please advise what adjustments need to be made when changing the developer/drum assy.
                      I have a spare from another machine.
                      Regards
                      Dennis
                      • denis stokes
                        Originally posted by deep
                        Hi denis,
                        Check it.
                        Can you please advise what adjustments should be made after changing the developer/drum assy.
                        Dennis
                        • denis stokes
                          Please advise what adjustments must be made when changing the developer/drum ass on a EP5000.
                          Dennis
                          • nmfaxman
                            • 1704
                            Clean the machine, then clean it better, then clean it even more.
                            Run 200 copies. The deposits will be obvious because the area toner drops in will be dirty.
                            • deep
                              • Jun 2008
                              • 208
                              If the spare unit is in condition and the copy quality is good, no adjustment is necessary.
                              If bad copy was found (too dark or too light), you have to carry out Auto and Manual Exposure adjustments.
                              Kenny
