Konica-Minolta 450/420
  • tariq65
    • Jun 2010
    • 84
    i have problem in this machine he is giving me messege "Replace Heater Assembly".
    and machine is not enter the programm. so tht's why please help me about this trouble.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    It is either an error in the fuser which can be reset using the trouble reset procedure. Or the fuser has reached end of life and needs to be replaced.
    • Rudi
      • Jun 2007
      • 251
      Try holding in the utility key while switching on the machine , if it gives you a trouble reset option then press st00st01 , sometimes you can enter service mode that way , else you have to replace the fuser.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        When the web counter reaches it's limit you get the "Replace Fixing Unit " Message. Replace the WEB and reset the Fixing Counter.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • suso73os
          • 38
          You must change the fusing unit or you can replace the fuse that comes into the unit is a 62ma fuse, sorry for my bad english.
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
            Paul@justmanuals.com
            • Tonerjockey.com
              • Jun 2010
              • 41
              1. Enter Service Mode.
              2. Select [System 1].
              3. Select [Initialization].
              4. Select [Counter Data].
              5. Select [Fixing Counter].
              6. Press the Start button.
              7. Exit the Service Mode.
