C6500/C6501 Black spots on Black Drum
  • ni311
    • May 2008
    • 658
    #46
    Re: C6500/C6501 Black spots on Black Drum
    The latest info I saw about this subject from KM is that it is a problem with the cleaning blade, we were advised to replace the initial cleaning blade from the du-102c with the one that it is fitted du-104 but without giving us a part number for this blade. The main difference between these two is an anti-vibrating piece that is on the cleaning blade of the du-104. Also, if you are doing this, you have to update the firmware on the machine with a version that was not released yet... This last process prevent the cleaning blade to flip, same problem that was present on the first du-102.
    Anyway, it is much easier just to change the du-104 as a whole. I'm not sure if it is cheaper or not.
    Konica Minolta Error Codes - Explanations and Solutions
    • Bizhub
      • 147
      #47
      As everyone has said .................................
      Fit Du104 drums and throw the 102 (A B or even C's) into the bin. This is becomming more and more the norm for K-M ! They keep cutting costs and reliability is now suffering.
      We have heard excuses about temp , humidity and even too many black and white copies made !!!!!!
      • ni311
        • May 2008
        • 658
        #48
        After drawing the final line, I'm not sure KM cut the costs. I'm sure a lot of du-102C returned to the manufacturer. I just hope it won't apply the same measure to du-104.
        • ineo+6501
          • Mar 2010
          • 262
          #49
          I'm told by a reliable source that KM will soon release a TAD/TNI regarding this in the near future (in the UK).
          The fix will be to fit the DU-104 drum.
          • ni311
            • May 2008
            • 658
            #50
            It is already out. The id is TNEU1200014EN00, it appeared somewhere in the first days of February 2012. This was available for Europe region.
