BizHub C250 Remote ip change
  • Serdar
    • 18
    Hi All Friends
    I have a bizhub c250 and touch panel doesnt working.I need to change ip but i cant do this because touch panel.Is there any utulity to do this.
    Thanks all
  • ineo+6501
    • Mar 2010
    • 262
    Enter the current IP address into your web browser (firefox, not IE). Log in as administrator (password 12345678, and look in the NETWORK tab?
    • ineo+6501
      • Mar 2010
      • 262
      My bad sorry, it can't be done this way. Fixing the panel seems the only way.
      As a long shot, Pagescope Data Administrator may do the job?
      • RRodgers
        • Jun 2009
        • 1947
        Why not?
        • ineo+6501
          • Mar 2010
          • 262
          I tried it and the IP etc were uneditable. Should you be able to in PSWC?
          • RRodgers
            • Jun 2009
            • 1947
            Did you UNcheck DHCP?
            • ineo+6501
              • Mar 2010
              • 262
              Yes. We never use DHCP, always a static.
              • Serdar
                • 18
                Thanks all friends but i have to wait new tocuh panel
                • RRodgers
                  • Jun 2009
                  • 1947
                  Are you logging in as administrator?
                  • ineo+6501
                    • Mar 2010
                    • 262
                    Yes as administrator. I have upgraded to the latest firmware and now it works, very odd.
                    Cheers
                    • Serdar
                      • 18
                      Login as admin means login to PS or to copier?
                      • TheOwl
                        • Nov 2008
                        • 1732
                        Login into the PageScope Web Connection (Web Interface for the copier by using the machines current IP address as the address in Internet Explorer or Firefox).
                        Once you are there, you will need to log out of 'Public' and login as the 'Administrator'. You find a button that says something like 'To Login Screen' or 'Logout'. You can then select 'Administrator' and login using the admin password which by default is 12345678.
                        Now click on network (if you can't click on network, then click on the refresh button within the web page, not on the web browser) and you should now be able to edit all your network settings.
                        If you are still having issues when using Internet Explorer then doing the following:
                        1. In Internet Explorer, go to Tools then Internet Options
                        2. Under Borwsing History, click on Settings
                        3. Click on Everytime I visit the Webpage
                        4. Ok then Ok again.
                        If there is still an issue, then you will have to update that firmware as it could be an issue between the machines firmware and the version of .Net Framework that is running on your computer. Old firmware can't understand the newer versions of .Net Framework which is heavily tied into Internet Explorer. You can get around this by using Firefox though.
                        • Serdar
                          • 18
                          Thanks your detailed informations...i know these but i dont know the machine's ip and we an not on the same gateway!!!So i cant do this from Web Connection
                          Thanks a lot
                          Serdar
