Konica1212
  • cliffhangers
    • Feb 2010
    • 243
    Konica1212
    Good day,The PM indicator lights for periodic maintenance is up for a konica1212,please i kindly need your help how to perform it.i will be greatfull.THANKS IN ADVANCE.
  • Luther
    • May 2006
    • 682
    The PM light comes on every 15,000 copies the developer is replaced at that time, the drum is 60,000 DO NOT RESET THE PM COUNTER without running L-detect for the developer or the machine will code out 47 mode 90 is pm count reset and 47 mode 51 is L-detect reset drum count 1st then run dv setup...hope this helps
