We have a customer who has a Konica 7115 copier with a bad drum unit . How do you remove the drum unit, and is there a reset that has to be done after replacement. Thanks for replys.
konica 7115f
If not, then I can tell you that to remove the drum unit you need to open the front and right doors, and on the front remove two screws that hold the drum unit in place. Pull it out and there you have it.
I wouldn't go further without a manual, though. Good luck!' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
