Got a bit of an issue with the post inserter in this model.
It would seem that whenever I attempt to use the manual controls on the post inserter itself to send a stack of paper through the hole punch, there is no way I can set the hole punch to be 3 holes, instead of 2.
My best guess is that this is just the way it is with this particular unit as any effort to set to three hold in the control panel of the main body does not affect this.
Looking through SSD, I get the impression that this is fixed via special firmware for offline mode, but I am not sure if I can use a lower version firmware (v33) on a V60 flashed machine.
And of course, does this actually work...and even better, can the user switch back and forth from 3 hole to 2 hole?
