Bizhub 600/750
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Bizhub 600/750
    DV paddle auger/mixer drive gear keeps breaking off on the DV unit. Turns normal by hand. Why does this keep happening ? 2 different DV units.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    They beefed up the gears on the 600, I have never broke one. Are these 2 units on the same machine?
    • YouthAttack
      • Mar 2010
      • 37
      are they brand new oem dv units? the older ones were known to strip on the older model bizhubs.
      • SKTeK315
        Walter
        • Jun 2009
        • 142
        Bizhub 600/750
        Yes they are but both dv units with high mileage. Put in an oem dv unit & fresh dev. material. Friday is the test to see if Mach is the cause which I don't think so. Only the big gear gets the drive from Mach. That's fine.
        • SKTeK315
          Walter
          • Jun 2009
          • 142
          Very old. High mileage but OEM. Just put in a brand new out of the box OEM w/new OEM DV. We'll see what happens this Friday.
