C203 Laser ASsemblies: One or Four?
  • mrwho
    Major Asshole!
    • 4299
    Are they still sending the C203 printheads in four-packs or is it possible already to order just one? If so, what's the pn for one ph?
    Cheers!
    Mascan42
    Ibid
  • emujo
    • Jun 2009
    • 3009
    If you're a dealer you should be able to get the FOC replacement kits which are all 4. I believe you may have issues replacing just 1 as the PHs are a matched set. Emujo
    • JSC
      Gimp
      • Dec 2006
      • 618
      They come in a set of four. But you can just change the faulty one, and keep the three back for spares. We have done this quite a few times in the past as Konica Minolta are often sort of stock.
      The gene pool could use a little chlorine.
      • mrwho
        Major Asshole!
        • 4299
        Thanks. That was exactly my idea. I just wanted to know if KM had somehow changed its policy and allowed us to order just the faulty PH and not the whole set.
        Cheers!
        Mascan42
        Ibid
        • suso73os
          • 38
          After you change any laser unit you can use an special firmware for this machine to solve the laser error code and see if an error code reappear or not.
          • mrwho
            Major Asshole!
            • 4299
            Thanks. I'll look into that!
            Mascan42
            Ibid
            • IKy
              • 19
              Before! (Not after) almost every copier 203-253-353 (especially last 2) 2007-2008 has this problem and this firmware really helps avoiding laser unit changes
              • suso73os
                • 38
                • copyalbania
                  • Aug 2009
                  • 165
                  Hello
                  It is not possible to order one by one the hole order must be of four.
                  See attach file!!!
                  bizhub_c203_c253_c353_A02E_pagenumber.046.jpgbizhub_c203_c253_c353_A02E_pagenumber.045.jpg
                  • Stirton.M
                    All things Konica Minolta
                    • Oct 2009
                    • 1804
                    Cheers!
                    How did I miss this originally? I must've been sleeping....
                    A02E R702 11 FOC
                    That said, I recommend you change 4 as a set if you do the FOC program, though I think that has expired. See this post for my post on the subject....
                    The reason being, is there is a high likelihood that the remaining laser units may fail at some point and you will be forced to do the replacement again. This can be a major hassle as you no doubt already know, when replacing a unit.
                    It is your choice however...
                    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                    ---Groucho Marx
                    Please do not PM me for questions related to Konica Minolta hardware.
                    I will not answer requests or questions there.
                    Please ask in the KM forum for the benefit of others to see the question and give their input.
                    • spock
                      • 41
                      On initial release it was required that all 4 be replaced as they were batched laser assemblies, this policy was changed however and you can now replace them individually
                      • Stirton.M
                        • Oct 2009
                        • 1804
                        I agree, though I hate to take chances, and more to the point, hate doing the work like this more than once. Removing the units and replacing them is easy, its the getting to them that is tiresome.
                        ---Groucho Marx
                        • spock
                          • 41
                          yeah i with you on that one, depends on your budget i guess i would do them all personally as if i recall the notice about them involved faulty batches so the others are likely to fail.
