Bizhub 200 Network Fax Utility and WIN 7 64 bit
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Has anyone been able to use the Network Fax Utility with Windows 7 64 Bit? When I install it, it finishes with "Failed to install print driver". The Utility is installed but no printer pointing at it? Any solutions or work around is greatly appreciated.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
  • mo0651
    • 1054
    Seems to be some false advertising. Doesn't work with Version I Bizhub222 either.
