problem with the machine 950
  • Shlomo.s
    • Aug 2025
    Hello
    I have a problem with the machine 950 tells me to check the sorter stapler unet
    I checked the stapler in 47
    the Stapler works fine
    fs-611
  • albasoul06
    Actuator which detects the remaining quantity of staples is missing or broken. This may occur when replacing the staple cartridge improperly.
    • aleksander
      • 378
      so, what's the real problem with the stapler unit?
      • RRodgers
        • Jun 2009
        • 1947
        Yep, what he said.... they break often. Get the little black plastic piece.
        • jrs157
          • Jul 2010
          • 22
          SOmetimes if you're very very lucky and know what you're looking for, you will FIND the little mishaped small plastic part inside,under or near the copier
          AN ounce of prevention is worth a pound of obscure
          spare screws
