c350 image transfer belt fuse
  • brent
    • Nov 2008
    • 1214
    I know it is here somewhere. does anyone have a number that is on the fuse. or what will work? thanks
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Use a 1/16th A Pico type fuse. You can use a 1/8th in a pinch, but it is recommended to use 1/16th.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • brent
      • Nov 2008
      • 1214
      Im on it. thanks again
      brent
      • brent
        • Nov 2008
        • 1214
        they don't have any fuses that rating here. I guess I am going to have to order one..
        they have a 250 volt 500 milliamp. I guess it gets kind of confusing on if that is bigger or smaller then what I need.
        brent
        • JSC
          Gimp
          • Dec 2006
          • 618
          You need a 80 milliamp, a 100milliamp might work but I can't see a 500 working.
          The gene pool could use a little chlorine.
          • Stirton.M
            • Oct 2009
            • 1804
            You will have to go to an industrial electronics supply store for these. Radio Shack and other crap stores like that do not carry these specialized fuses.
            They are called PICO fuses...look a bit like a typical resistor package, but that is where the comparison ends.
            This link may help you get started....
            FUSE PICO FAST 62MA 125V AXL - 0251.062HAT1L
            Keep in mind, some places have a minimum order...
            ---Groucho Marx
            • BR549
              • 111
              Are you sure about that? I've never seen a pico fuse in a transfer belt. I've only seen them in fusing units. All the transfer belts I've refused had the 20mm glass tube with metal caps on each end. 80 ma.
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                BR549 is correct the fuse is a standard 20mm glass fuse ( often called a mini fuse ) anything from a 50 ma to an 80 ma will work the OEM here in Canada is 62ma. I use 63 ma because for some strange reason they cost half of what a 62 ma cost. The fuse is located behind the 2 little silver contacts. I have seen some posts were people say they can use a pico type fuse and short the contacts going in from the front of the machine without removing the belt, I personally just slide the belt out a bit and replace the fuse.
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
                • Stirton.M
                  • Oct 2009
                  • 1804
                  We get the pico fuses by the truckload here....I prefer them...easy to carry a bunch (I usually pack in about 50 at a time) in the wallet...if I find I need one at any call, its a quick in and out...wrap the legs of the fuse around the tabs of the fuse cover and I'm done. The glass tube ones I will agree are what would normally go there, but those are a bit harder to get it seems, not to mention keeping a few in the kit...
                  We also use the pico fuse as a signal to the next tech to replace the unit at the end of that cycle as it is more obvious than simply popping in another glass tube one, which is not so easy to tell, aside from the wear on the belt surface or the cleaning unit.
                  ---Groucho Marx
                  • daniel_p
                    pico fuses
                    Hi,
                    I'm in Boston MA USA where can i buy this fuses Pico 1/16 80ma Help please
                    thank you.
                    Daniel
                    • Stirton.M
                      • Oct 2009
                      • 1804
                      industrial electronic supply stores....consult your local yellow pages....
                      or, simply follow the link above....
                      ---Groucho Marx
