Had a 600 doing close to the same thing but only out of the bt 2 trays. Ending up being clutch that drives the vert rollers. Tech support said it was the power supply.
Anybody seen this on a Bizhub 600
I did not get an update today as I got stuck on a critical c550. We were discussing it and thought if the second sheet does not stop at the reg sensor, it would through everything off. If doing 1 sheet, it does not pause at the reg.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Thanks to all who responded. The problem was the reg clutch. No image on the second sheet due to timing being off.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Nice to know. Thanks for the feedback!' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
I've had similar issues before with an arcing transfer separation unit.
if so much as 1 hair on those silly "hairy" automatic corona cleaning pads is touching the wire in the home position you get problems such as this but usually a error code will follow..Comment
I got the habit of ripping those cleaning units out on those machines. I believe they're more trouble than they're worth - someone please correct me if I'm wrong.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
