Bizhub 1050
  • halia_merah
    • Sep 2007
    • 28
    #16
    heh!heh!heh!do u really wanna know....???
    • EmW
      • May 2008
      • 3
      #17
      I really wanna know. I have the same problem.How to bypass the password.
      • halia_merah
        • Sep 2007
        • 28
        #18
        wat password u want to bypass?
        • copycommerce
          • May 2008
          • 65
          #19
          I have a special hammer in my workshop for passwords,just remove the back door and BOOM Usualy i make a hard reset of the controller if there is one if not just a reinstall of the firmware
          • d7guitar
            • Jan 2007
            • 54
            #20
            Option 1: You would have to turn off "account track", or it's equivalent on the 1050 to negate the CE password screen and allow you access to the tech rep mode. IF you turn this off you WILL lose all of their account track data!!! Option 2: replace the system control board... There is NO way to retrieve the username/password by any "Backdoor" methods. Option 3: Let the key-op know of your pending cost of a replacement board and see if you can enlist their help in remembering the password and at the same time, letting them know the necessity of remembering the password. Option 4: Just a thought? Can you get into tech rep mode by holding the utility key down while powering on the machine???????? Best of luck.
            After all is said and done, More is said than done.
            • artfer
              • 24
              #21
              turn the machine on with the utility key pressed.
