Is tandem copying and printing available ?
  • kmcopytech
    • Dec 2007
    • 141
    [Electrical] Is tandem copying and printing available ?
    I have some konica machine (K7075 7085 7255 7272 7155 7165 and 750-920-1050), bizhub600 -
    How to set tandem copying and printing ?
    Any solutions?
    Thanks!
    kmcopytech@gmail.com
    Jack smith
  • albasoul06
    except bizhub 600 and 750 the rest have TANDEM
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      You are better off setting 2 machines up individually and manually splitting the jobs ie: if you have a 5K job send 2500 to each machine. If I remember correctly the Tandem setup means you have 1 printer interface and the jobs are split between the 2 print engines. This means you loose the ability to have a different print job running separately on each machine, ( someone correct me if I am wrong on this, we only set up Tanadom once , and removed it because of this issue), copying is not an issue.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • kmcopytech
        • Dec 2007
        • 141
        Can you provide Tandem setup/installation procedure for K7155 K7272 K7085 and bizhub 1050 series?
        Thank you!
        jack smith
