Re: NVRAM
I seem to recall the C-350 still using the old style Dallas NVRAM/real time clock which was a (28 pin?) plastic DIP format, no? (Or did they end at the CF-2002 and I'm mistaken??) Which means that part of the question is moot as they will not physically fit the 351/450. On the other hand they were easy to read and write with many EPROM programmers.
Other NV boards were indeed physically compatible - it was really all about the connector. Electronically, they're pretty straightforward devices - SRAM, a real time clock, and a power management watchdog.
Physically compatible means that they were electronically identical - but not necessarily the contents.
The reciprocal function of the NVRAM backup is the key sequence Stop-07139-clear, only available upon specific mismatch conditions and D/E codes.
Upon this sequence, the MFP loads it's NVRAM copy TO the NVRAM. Counters should remain intact.
