Recently moved my Colorforce 8050 to new office but, when turn on a printer is ok in touchscreen panel. I make a copy and as result is a perfect copy. My problem is when i press a PRINT key in panel, in the screen show a Controller info, after i press a MENU/ESC, select PRINT PAGES, select PS TEST PAGE and the printer send a PS CHART with color black, yellow & magenta perfect's, only cyan color is not fill in the chart.
The Fiery is internal and print by parallel port, before to movement to new office a Colorforce work perfect as print.
What happened?
Thank's
What happened?
Thank's
