6000 Duplex Misfeeds
  • AVux07
    • Oct 2007
    • 57
    I have a 6000 that tries to feed from the duplex tray but stops at the metal exit roller. I know there's a one way gear/clutch in the duplex drive train but the parts list only lists gears or pulleys. Does anyone know this clutch's P/N or can maybe point it out in the diagram? Otherwise, it's alot of work digging it out and leaving them down .
  • Claudio
    • Feb 2007
    • 235
    Minolta 6000 duplex jamming
    The 4 parts I used to replace when the duplex would randomly jam are :
    Shaft PN: 1075-2672-01,
    Shaft PN: 1075-2597-01,
    Gear 27T (1-way) 1075-2671-01,
    Gear 35T (1-way) 1075-2595-01.
    I could never figure out how to take appart the specific area to replace these parts so I would just bend the frame out of the way to replace these parts because they were very difficult to get to and it will save you a lot of time. Then bend the frame back. Worked for me.
    Good luck. Maybe you'll find an easier way.
    Claudio
    • AVux07
      • Oct 2007
      • 57
      Thanks Claudio, that's just the info I need. Bending the frame should be in the disassembly handbook!
