Konica 7165 error code 49-04
  • Machinercylr
    • Dec 2006
    • 73
    Looked in intravia's manual and found nothing remotely close to it. What can be the probable cause?
  • njkid
    • May 2009
    • 6
    Possible hard drive failure in IP-511. If hard drive is ok, writing system code back onto hard drive should correct issue.
    • minimerlin
      • 851
      Yep, problem with controller, sometimes the unit just needs to cool down and then works ok. Is the machine hard against the wall..it needs vent space for the controller. If code comes back you will need a new drive.
      Please do not PM me without asking first.
      • Machinercylr
        • Dec 2006
        • 73
        I will try this......Copier is up against the wall,And have informed the user what might be expected f this does not clear-up this,...Thanks for the wonderful info....Best Regards,Steve
        • remati
          • 149
          ..look at the fan if it is work well and if it is clean...
          ..the fan of the IP,of course
          • Machinercylr
            • Dec 2006
            • 73
            Scheduled unit for cleaning of fans
            It has been a awhile since the back shroud has been pulled, I was thinking of this last Friday, ....A little P.M..Thanks for all that has acknowledged my Thread......Steve
