6500 Starter Counter
  • Kilangz
    • Jul 2025
    Hi to everyone anybody knows why i cannot reset the starter counter of the Bizhub6500.
    I Follow the Procedure on the manual but after you return from the Normal Copy menu every data is still there. The Developer Count now is Almost 400%..
    Any help will be Much Appreciated.
  • ineo+6501
    • Mar 2010
    • 262
    You have to clear the counter before you add the dev and run toner initial etc or the count won't clear.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Resetting the count is possible from my experience.
      The question I would be asking, is are you resetting the developer unit or the developer itself? There is a difference.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • Kilangz
        i want only to reset the DEVELOPER/STARTER count. actually all of the counter in the PM PARTS list is reseted except the STARTER count.
        • maxtrax
          • Jan 2008
          • 27
          you can reset the developer counter by hand but you have to perform the "toner density sensor unit" to reset the distance of the developer. Peform this test only when you replace the developer.
          never change a working machine
          • Kilangz
            I'm going to reset the developer count first and then perform the toner density initialization or in reverse?
            • maxtrax
              • Jan 2008
              • 27
              dus not matter
              • albasoul06
                When trying to reset the developer counter in the Special Parts Counter, the page count resets, but not the distance count.
                CAUSE: The Toner Density Sensor Auto Adjust was not performed.
                SOLUTION: Please perform the following:
                1. Enter the Service Mode.
                2. Process Adjust.
                3. Drum Peculiarity Adj.
                4. Perform the Toner Density Sensor Init adjustment.
