Error code C6020 on Kyocera CS 3550
  • sunrise123
    I am getting an Error Code C6020 on a Kyocera CS 3550
    Can anyone help?
    Thanks!
    Terry
  • Luther
    • May 2006
    • 682
    High temperature fixing error,good luck
    • guru
      • Aug 2006
      • 18
      Replace Fixing Unit. Thermistor is not working properly.
      not outsourced yet ...
      • rich2764
        • Jun 2025
        Order the modified fuser plug connector. There is also a later firmware update to fix this code. This code happened to me on a few selected machines after I did firmware upgrades to add the interrupt button on the touch screen and to speed up the loading time. The thermistor is not guilty!
        • ijoberg
          How can we clear this code in the short term ? It only occurs when it is very hot, but works fine for months between getting this code.
