di3510f drum replacement
  • memphis
    • Sep 2009
    • 13
    Hello I just replaced the drum on the DI3510f because it was creating streaks. Now the streaks are gone but the prints are very very light. I've cleared the counters and run F8 already. Any suggestions? Thanks.
    Edit: Now it's just printing blank copies.
  • kalindd
    • Jun 2008
    • 192
    Looks like your charge corona is not located properly e.g. not good charge.
    Check everything again.
    • Cantechman
      • Nov 2008
      • 228
      You should not run a F8 unless you replace the developer as well. You probably have to replace that and run F8 again.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Sounds like week developer.
