bizhub 164 not displaying service mode
  • CKiiza
    • Feb 2010
    • 77
    i have this bizhub 164 brand new piece to install. the trouble is for the initial ATDC adjustment, the machine is not displaying service mode. I expect that when the select key is pressed the machine should display among others utility and service, it displays utility along with other functions but not service mode. checked the service manual but doesn't seem to have a definitive procedure. anyone knows a way to get to service mode please?
    Thanks for the help
  • pakalo
    Hi dear guys,
    here the correct procedure for enter in Rep. Tech. Mode:
    Menu/Select
    Quick Setting
    Quick Setting
    + or - & FUNCTION Menu/Select
    + or - & TCR AUTO ADJUST.
    Ciao ciao.
    _______________________________________ Pakalo ____
    • mrwho
      Major Asshole!
      • 4299
      Pakalo is right.
      Check page 120 of the manual PDF (page 83 on the printed version).
      Mascan42
      Ibid
      • CKiiza
        • Feb 2010
        • 77
        Thank you so much. it was very helpful. installed the machine and it worked very well. thank you again.
