Konica Minolta CF2002 not working
  • violet
    • Aug 2025
    Side door open message. Door is closed and customer has a chair leaning on door to make sure door is closed. Still has message and will not work.
  • mrwho
    Major Asshole!
    • 4299
    Simple things first: Did you check for the switch/sensor that detects the door open/close operation?
    Mascan42
    Ibid
    • TheOwl
      • Nov 2008
      • 1732
      There are also two clips that break quite commonly.
      Check the latch for the side door and make sure that both ends are indeed in a good condition. Sometimes they will crack and not break which also can give a similar problem.
      • RRodgers
        • Jun 2009
        • 1947
        As Owl has suggested check the hooks that hold the door closed. They are common to break.
