DI 620 - error C0220 and C0200
  • mcprest
    • Sep 2010
    • 19
    I have a Di 620 with problems: c0200 and c0220. i have studied the manual and i cleaned all the parts involved, i have changed the HV1 board and the HV2.
    Sometimes it prints 200 copiesuntil the errors appear sometimes it prints none (the error appears after i press start).
    I have made the F2 adjustments, The F8 and F5.
    I have no ideas, please help...
  • mcprest
    • Sep 2010
    • 19
    I have also checked the quantity of developer and it's good (820g). And i have cleaned the developer station entirely.
    • montana
      • Aug 2008
      • 392
      hi...check or replace the mc charger corona..or the t/s corona
      i guess there is a charge leak
      i hope this help
      regards........
      • tonerspot
        • Nov 2008
        • 79
        check drum ground plate
        • mcprest
          • Sep 2010
          • 19
          about the drum ground plate - i have checked that, cleaned her and measured the conductivity and it's ok
          about the mc charger corona..or the t/s corona - i guess it's about the isolated heads ?? i proceed to make a double isolation on them, but the result is the same. I have even changed the charging corona and the transfer corona from a di 520 that is in good function conditions, but problem still persists. ...
          • mcprest
            • Sep 2010
            • 19
            please help......
