Thanks guys I got the 3rd cassette to start working. But it broke my 34t gear (paper lift gear) and I think it is due to alignment of the gears to the paper platten. Does anyone have any info on this? thanks
Thanks guys I got the 3rd cassette to start working, but
I never heard of anything like that (which doesn't mean it can't happen, mind you). Couldn't it be that you had a weakened gear that broke when you fixed whatever was the initial problem?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
No that gear along with 2 other gears were brand new. What happened the paper platten went up and even though it reached the top the motor kept driving the paper platten up which broke my 34t gear it happened really fast. That is why I feel there is an alignment even though the paper empty/full sensor seams to be working fine. There are a couple of gears with hubs that bypass photo sensors.Comment
There should be a sensor in the machine that tells the tray lift to stop when the paper is at the top...sounds like yours is not working, maybe the actuator is broken off, I have had this happen in the past.Please do not PM me without asking first.Comment
If this problem occurred after you serviced the DB. Note it is very important that you disconnect the ribbon cable before trying to remove the paper drawer. If you made any attempt to remove the drawer without first disconnecting the ribbon cable, then the cable is probably damaged and causing your issue.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
