Konica 8050 colour problem
  • radymob
    • Feb 2010
    • 21
    I have konica 8050 with colour problem. This problem start with a blue backgroud on page with text and one photo, restarted the copier no more blue backgroud on print, but all colours are very bad.
    I performe "Test pattern density" on 255 and all colours are OK. I'm confused where can be the problem.
    I attached one example off how it print.print.pdf
  • mrwho
    Major Asshole!
    • 4299
    If the machine's interal patterns come out ok, seems like you've got some problem related to the print controller. What happens if you try to print the controller's test pattern (the one with the fish on it)? Post it here, if possible.
    You could check the controller's data cable, for starters.
    Mascan42
    Ibid
    • radymob
      • Feb 2010
      • 21
      print1.pdfTest page,
      I,ve also change my Fiery ( i have two), and the problem persist
      • bigdcopy
        • Dec 2010
        • 70
        have you tried to calibrate the controller (auto cal if you don't have a spectrometer), also check the gradation levels in the printer gamma adjustment
        KONICA MINOLTA 8050 Field Service Ver.2.0 Apr. 2004 36 MODE
        1-81
        I ADJUSTMENT
        1
        7.4.2 Printer gamma adjustment
        When the color reproduction is in poor condition,
        conduct this adjustment to correct gradation.
        A. Procedure
        (1) Printer gamma offset adjustment
        Conduct this adjustment when the color reproduction
        varies with copy modes to correct the gradation
        in a high light density section and adjust the density
        in the background.
        Note:
        • For the printer gamma offset adjustment,
        adjustment methods of 0 to 5 are available for
        each screen type. It is possible to divide the
        gradation in 256 into 6 parts of 0 to 5 and
        adjust the entire ranges from "0: Low density
        section" to "5: High density section."
        • In default, adjustment is limited only to "0 (low
        density section)." When setting DIPSW 28-4 to
        1, adjustment can be made on the entire
        ranges of 0 to 5.
        • Be sure not make the adjustment of "Printer
        gamma offset adjustment (ED-8) (0 to 5)."
        a. Procedure
        1.
        Enter the 36 mode.
        2.
        "36 mode menu screen"
        Press the [3. Image quality adjustment] key.
        3.
        "Image quality mode menu screen"
        Press the [2. Printer gamma adjustment] key.
        4.
        For the printer gamma adjustment, the following
        items are provided:
        [1. Printer gamma offset adj.]
        [2. Printer gamma sensor adj.]
        [3. Printer screen gradation adj.]
        5.
        Press the key of an item you want to adjust.
        6.
        Press the [PREVIOUS SCREEN] key to return
        from each of adjustment screen to the "Printer
        gamma adjustment menu screen."
        1.
        Enter the 36 mode.
        2.
        3.
        4.
        "Printer gamma adjustment menu screen"
        Press the [1. Printer gamma offset adj.] key.
        after doing this do auto gama to lock it in
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          I attached one example off how it print.[ATTACH]7514[/ATTACH]
          If internal test prints do not yield results, the only thing that can be an indicator of an issue is the VIF, cable or fiery. Since you replaced the fiery and the problem persists, it may be the cable or the VIF card. Swap the cable around so the connectors are reversed. Check the VIF and ensure it has a good connection internally.
          And FYI, on issues like this, best to do halftone tests at half density...120-150 or so...setting at 255 can hide issues like this if it is the mainbody.
          ---Groucho Marx
          • radymob
            • Feb 2010
            • 21
            Thank you all, it was cable between printer and controller
            • mrwho
              Major Asshole!
              • 4299
              Another satisfied customer.
              Mascan42
              Ibid
