Bizhu C220 spoiling developing units.
  • CKiiza
    • Feb 2010
    • 77
    [Electrical] Bizhu C220 spoiling developing units.
    I have this C220 machine which is spoiling developing units. it all started with the client using the machine even when it was out of black toner. since then, the machine has been spoiling developing units within 1 day work in the machine. I have since replaced the high voltage and printer control boards though either way the machine still did exactly the same thing.
    any one out there seen this before and solved it.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Spoiling Developer Unit? Do you mean you end up with a C2557: Abnormally low toner density detected black TCR sensor? If so I would check the add toner mechanism and make sure the toner bottle is properly installed.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • CKiiza
      • Feb 2010
      • 77
      well it is pulling out the developer from the unit. it doesn't show at first but after some time the the machine doesn't produce black toner on the printout. it only puts a little developer on the print out. I guess most of it ends up in the waste toner box.
      • ccfc87
        • Feb 2014
        • 18
        Re: Bizhu C220 spoiling developing units.
        Did you find a solution to this problem. I have a machine doing the same. New magenta dev fitted last week. Now no coverage on mag roller yellow unit has done the same too. And washed out copies. The drums are new itb new.
        • AjitN
          • Mar 2009
          • 287
          Replace black Drum Unit.
          This is very common problem.
          Hope this helps
          • pepper38_cnd
            • Aug 2005
            • 1075
            Replace the relay board unless this is an exstreamly dirty enviroment then just keep replacing the drum early.
            • Synaux
              • Mar 2012
              • 1224
              Dirty environment = fabric softeners as a pre-filter for everything.
              Works great and freshens!
