Several machines are generating a black band at the bottom of the page when sanning in Compact PDF. This does not happen when scanning in PDF format. Any Ideas as to why this might be?
C35 Copact PDF Black Bands
I believe its a firmware issue and only affects when using compact pdf. Are you scanning ftp or smb?Comment
I'm thinking a firmware issue, or perhaps hard disk/memory related. Being in multiple machines, I am hesitant to say this is a certainty.
Update the firmware first to ensure it is the latest. I do not know these machines well, but I would assume there is a means to test the memory onboard and possibly reformat the hard disk along with a memory wipe. On the larger floor machines, one touch data and user configuration settings (network, device defaults) are usually erased with a memory clear process. I am taking the assumption that if this machine is capable of doing this, a similar action will take place. Be sure to back up the information before you attempt this process.
Swapping the memory with another stick of RAM might resolve this too, but bear in mind the memory on this machine is proprietary to KM, you will not find it sold in stores."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
