Bizhub c250
  • joegarzf
    • Aug 2025
    Bizhub c250
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    The only information the manual has is to remove & re-insert the fax board, and if that doesn't work, to replace the fax board. I would leave the fax board out of the machine if re-insertion doesn't fix the problem, so at least the customer has the other features available until the fax board is available. I guess it goes without saying to do all this board re-seating with the machine unplugged.
    Kevin900
    • mrwho
      Major Asshole!
      • 4299
      Check if the fax board is installed in the correct slot - if it isn't, it will give that error.
      Mascan42
      Ibid
      • NEOTECH
        • Dec 2010
        • 69
        jest only unset or uninstal tha fax board.
        • mrwho
          Major Asshole!
          • 4299
          ROTFL!
          "The copier is malfunctioning!"
          "Just don't use it!"
          Mascan42
          Ibid
