Bizhub C252 Scanning issue
  • kmteck
    • 37
    Hi Everyone,
    Having this weird issue with scanning. The machine will separate all pages when scanning. In other words, if one sets 10 pages on the doc-feeder it will send 10 individual files to the shared folder. I have checked the setting "separate scan" on the scan settings and no change.
    Thanks in advance....
  • BIG PAPA
    Da Boss
    • 234
    Make sure that the HDD is set on, Then in your scan settings you should have the choice for single page pdf or multi page.
    sigpic
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Maybe your default file type is not set to PDF or tiff all other file types do not support multi page files.
      Now into Ip TV KODI Boxes
      • knpgazem
        • 35
        I have to agree with BIG PAPA on this one. it is a trip for young players. when the HDD is either swapped (faulty) or installed from new, it may not be "installed" and the copier can only scan and send one page at a time.
        in the tech rep mode, system 2, HDD "installed. there may be a requirement to perform a logical (not physical) format etc.
        reboot and you should see a noticeable change.
        • kmteck
          • 37
          That fixed it.
          Thanks so much for all your help guys!!!!!
