C6751 C200Lite
  • lanierboy
    • 149
    [Error Code] C6751 C200Lite
    Hi All,
    I have a C200Lite with C6751 CCD Clamp error, I have cleaned all the optics etc but the error will not clear.
    before i go and spend a fortune on the machine has anyone had this before,cure??
    many thanks
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    19.5.97 C6751: CCD clamp/gain adjustment failure
    Relevant parts
    MFP board (MFPB) CCD board (CCDB)
    Step Action
    WIRING DIAGRAM
    Control signal
    Location (Electrical
    component)
    1 Select [Service Mode] → [State Confirmation]
    → [Memory/HDD Adj.] → [Memory
    Bus Check] → [Scanner→Memory], and
    conduct the memory bus function.
    2 Check the connectors between scanner
    section and MFPB for proper connection
    and correct as necessary.
    3 Change MFPB — —
    4 Change CCDB — —
    Relevant parts
    Exposure unit CCD board (CCDB)
    MFP board (MFPB)
    Step Action
    WIRING DIAGRAM
    Control signal
    component)
    1 Check the connector between CCDB PJ2-
    MFPB PJ01 for proper connection and correct
    as necessary.
    2 Check for possible extraneous light and
    3 Clean the lens, mirrors, CCD surface, and
    shading sheet if dirty
    4 Correct reflective mirror of the scanner if
    faulty, or change scanner.
    5 Change CCDB — —
    6 Change MFPB — —
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
