I have a C6501 and recently we've had a color issue that the tech can't seem to resolve. The color is not consistent from the left to right side of the sheet (when holding an 13 x 19 Sheet Vertically) There is a strong Magenta cast that is affecting the color on the left side of the sheet. This is most apparent in halftones. We've tried the density adjustment in the machine but its not working. The tech has done a full PM - replaced Drums, Corona, Dev. Housing, Developer, etc.
The best way to describe it is like there is a gradation of magenta from the left to right of the sheet - worse on the left side (ie. problem is on the left side and gradually gets
better as it moves to the right). I've attached a file that emulates the issue...
Hope someone can help...
